Is it possible to hide dimensions in the web sketchup? The “display” pullout
has controls for objects, planes, cuts, axes and guides. But nothing for dimensions.
I would guess that it would be easy enough to do by putting all of your dimensions on a separate layer and turning the layer on and off.
Is there a way to “select all dimensions” and easily get them to a new layer?
you can also select the particular dimensions and right click to use the option “Hide” if you just want to do it for a particular scene. After, just select undo and the dimensions will return.
re the layers, There is no quick way. You need to allocate all the other items in the drawing to their own layers (or tags). Then you can turn those layers off and whats left will be the dimensions which you can now select together and allocate them to a new layer.
