Hi,
Is it possible to lock frame in layout?
Hi,
What do you mean by “frame”? You can put entities on a layer that you then lock which will prevent them from getting modified accidentally.
Hi DaveR,
The “frame” I mean is the blue rectangular line around a model that is inserted on layout.
I asked this question because many times I moved a model position accidentally when I was doing annotation or dimension etc.
Put the annotations and dimensions on a different layer from the model viewports. Lock the layer for the viewports and you won’t have any problem. Make sure the text layer(s) is higher in the stack than the layer for the model viewports.
Yes…it works…thanks
