how can I avoid that the blue frame change in Layout, when I change the layer in Sketchup and update
It means I have allways to adjust the position of a layer in layout after I changed somethin in the sketchup model.
This makes not sense for me because I have 2D line and text and all made printable and then it move away from his position.
BTW: Maybe anybody know a video how explain this. I’m not really happy with this frame concept. For me is this frame concept not logical. Maybe I’m not so familar with all. I’m open for good advice.
Yes! I did. IWhen i have forgotten something or add it a new part, so i have to update and save it to update in Layout. But why the frame move and even the size of the frame change.
In SketchUp, set up your view as you want it to appear on your LayOut page.
Still in SketchUp, create a Scene from you view. Update your Style if needed.
Save and send to LayOut.
In LayOut, select your SketchUp viewport, and in the SketchUp Model tray, select the Scene you added instead of the “Last saved SketchUp view” to be the source of the viewport.
This mean that all your SketchUp scenes that will be stacked in Layout In order to create a construction drawing, have to have the same view (setup in the style manager in SU), something like have the scenes aligned.
