Involute gear and worm gear plugin?
You might find this interesting.
http://computers.martinchick.com/spur_gear.html
There’s a calculator at the link. Enter the number of teeth to suit the gear ratio and leave the Diamteric Pitch constant. The calculator will give you the Pitch Diameter to suit the number of teeth.
Screenshot%20-%205_11_2018%20%2C%2012_05_21%20PM
In order to have two gears properly mesh, they need to conform to certain requirements. You usually start with a ratio that you desire as the output and work backwards. For example, if you want a 2:1 ratio, then one gear needs a circumference that is twice the other. Perhaps a 1" diameter gear and a 2" diameter gear. If these are represented by circles, then they would look like:
To keep the teeth size comparable, the number of teeth on gear B needs to be twice the number on gear A. It’s generally not a good idea to use less than 8 teeth, so looking at 8 teeth on A:
and 16 teeth on B:
you get:
Looking at this, I would probably then go with 10 or 12 teeth on A and 20 or 24 teeth on B:
[added] I didn’t want to give the impression that you have to use an even number on the smaller gear. Here’s another example:
However, the ratios of diameters and teeth must be the same.
Thank you!!! This makes perfect sense now, not sure why I couldn’t wrap my brain around it before!
