The dovetail geometry outside of the case side overlaps that inside the component. With doubled up edges, it’ll be harder to tell if you’ve selected the geometry.
By the way, don’t forget to make a component for the panel.
I guess the thought that you can push a dovetail key through a case side that is not a part of the shelf that it becomes a part. It is easy for me to understand pushing the dovetail mortise in the shelf or better using Enroth trim.
If you add the dovetail to the end of the shelf you can then either use Trim from Eneroth Solid Tools to trim the case side or you could open the case side component for editing, trace the tail and use Push/Pull to push in the socket.
Yes, I think that is easy either way. I had issues making the key at the end of the shelf. I’m not sure what I did wrong. I will try to slow down and do it again. I did not realize that the door panel needs to be created as a component. Is that what you meant when you wrote that I need to remember to create a panel component?
I have a problem now keeping the shelves as solid components. I can add the dovetail keys in place, but somewhere in the process the shelves turn from solid components to plain components.
Not yet. I undid each step of making the dovetail key until the shelves were two solid components again. So, if I send you the file now, there will be no dovetail key. But, here it comes anyway. Cab Basics.skp (86.6 KB)
Now, I’m having an issue with follow me. After double clicking on the top and using select/shift to unselect the two back edges, I select the follow me tool. As soon as I select the follow-me tool, every part of the top is unselected. I extruded, but it went all the way around the top, to include the back edge. So, I undid it. How do I keep the follow me tool from unselecting the part I want to extrude/route?
I had quite a time with the hinges. I don’t know what happened to the Bottom/Top at the end. Anyway, I’ll pick it up tomorrow from here. I’ll do what you think I should at this point before I go on to video 5.
