Intro to printing a drawing on Sketchup Pro 2024?
You have a template in SKP with Scenes and Tags already built in. You adjust these (usually just a Zoom Extents, maybe tweak a few tags) and then ‘Send to Layout’. You pick your LayOut Template and the scenes populate the views you have setup on all the pages.
For a document like this one in the video I would update the project name then put a few dimensions on the plan and maybe the section view, then Export to PDF, save the LO file, and email it off to the client.
I have several of these built with all my client’s logos and inofmration built in - so depending on what I’m doing I just pick the template, delete any pages or views I don’t need, tweak the text, add some notes and off it goes.
For 1 page I have likely taken longer recording the video and typing this reply than it would to prepare and export once I had a template setup.
Thank you! I will give it a try!
I’d like to understand your method better.
It sounds like you start with a dummy sketchup file which already has drawing in it, and is already linked to a layout file when you start drawing a new project. I’m not sure what it means to relink . . . Or do you just start with the blank sketchup template you created with your own scenes and tags?
I just completed the Layout Essentials and the Layout Design Package. I see how I can be more efficient. Things are almost coming into focus.
Basically yes. There’s already a .skp file inserted into the LayOut template. The reference .skp file is listed in Document Setup>References. To relink it, select the file, click Relink, and choose your project file.
Alternatively you can send the SketchUp file to LayOut and choose the template with the dummy file. LayOut will replace the dummy with the project.
To make this work correctly it’s critical that the scene names in your project file match the scene names in your dummy file exactly.
Notice I also have a spreadsheet file (.xlsx) in the template shown. It gets relinked to the spreadsheet for the project.
Awesome! That is extremely helpful! Thank you!
