Every time I have attempted to install SketchUp Make, the installation procedure is halted due to this error message.
Component Universal CRT (Hotfix KB2999226) has failed to install with the following error message: “The installer for the Universal CRT (Hotfix KB2999265) timed out after 10 minutes. Please restart your computer and try the SketchUp installer again. If this does not fix the problem, use Windows Update to install the latest updates and try again. (Trimble Code 6)”
The following components were not installed: - Visual C++ “14” Runtime Libraries (x64)
The following components failed to install: - Universal CRT (Hotfix KB2999226)
See the setup log file located at ‘C:\Users\Rick\AppData\Local\Temp\VSD6D6.tmp\install.log’ for more information.
Is there a way to correct this and complete the installation?
Then go the pinned thread by the SketchUp Team, and read part 5, for the links to the standalone download from Microsoft C Runtime redistributable library:
