Insert a node directly on an existing path between two nodes
hello guys
@keith_thurlow
maybe this is a question already asked or there is a shortcut to do it? but as I did not find anything?
Would it be possible when you want to insert a node on a white path to select this path (it turns yellow) right click to create a new node and when the path is yellow the node is inserted into this path and remains welded to the path
for the moment I break the white path, I create a new node and I reconnect the path
Great suggestion,
We do have a concept for something along these lines.
We do have another feature that might help, does it meet your needs in the meantime?
You can click-drag off existing connections (depending on the direction will determine whether you split from input or output):
@keith_thurlow
thanks Keith, I use the method you mentioned, it was indeed a suggestion :+1:
