The lights shine through the kitchen shelf.
Hi, I wanted to know if someone has the same problem with the lights. They cross the ledge and I don’t know what to do, I tried to lower the intensity away from the wall and closer to the edge of the ledge, also change from light rectangle to light mesh and the same thing happens.
Good afternoon! try so that the light source does not lie close to the object
Like @Eldar said, V-Ray lights that ‘cut’ into geometry can cast light inside of walls and objects and then ‘leak’ out in places where it’s not intended to. Try to maintain a small clearance from all sides and see if that solves it. If not, feel free to upload the model for further inspection. Cheers.
