Please fix this issue, a white box is blocking between the dimension unit and the dimension lines, instead of clear, and the text box should fit the text corners
@samuelsibal If you are using LayOut 2023.0, you can now adjust the text background transparency. This should fix the issue you are seeing.
Adam
