Impossible export from layout 2023.1
hi sketchupers, today I want use lay out export, but its impossible, I tried pdf, png, jpg, but everytime lay out freeze and then i forse quiet program, I’m mac user, onle I have like this problem?
I dont see this. Have you tried pdf-print from the print dialog?
Hi katilina, as miali.s has indicated you are likley seeing a slow down because LO is exporting all your viewports as Hybrid renderings with the new Output Override feature.
You can disable this feature (per document) (File → Document Setup…-> Rendering ).
Please see post here for details on the feature.
Trent
thanks, I turn off & now work,
also pdf export
