Hi All
Ive imported an image to use as a logo but it wont export as a 3d model
any advice would be amazing
thanks in advance
Paul
A raster image remains a raster image even if you import it into SketchUp. If you need a 3D vector representation you can try tracing over it with SketchUp tools to reproduce the shape, or if you have access to a vector file of the logo you can try converting it into DWG, DXF or other format SketchUp understands and importing that into SketchUp.
That is wonderful, thank you very much ill give a vector file a go and let you know.
Depending on the intricacy of the shape, it might be desirable to use a large or very large import unit (found in the import options dialog) when importing it into SketchUp, and to scale it down afterwards to the desired size.
Thanks, i’ve gone into my extensions manager and cant find TIG’s ImageTrimmer, any advice
Image Trimmer is part of the SKM Tools which is available through Sketchucation.
