I have imported some images into the same SketchUp file - some are opaque and others are partially transparent. All files were created with zero transparency and were exported with same settings. No effects have been applied to the images within SketchUp after importing. I’ve tried multiple images and the effect seems to be random. Any ideas?
Can you share the SketchUp file so we can see what you are working with and how you imported them? Are you still using SketchUp 2016 as indicated in your profile?
I own 2016 but for some reason downloaded 2015 when I setup my new computer.
I’ve found out the transparency has something to do with styles. In the default style the images are opaque, but in other styles the outlines show through (not faces or colors).
It seems to be just a program issue with non-default styles showing lines thru images saved with a transparent background. It seemed random until I figured out all the issues.
