Bonjour, je souhaiterai importer un fichier IFC ou dwg mais cela ne marche pas sur sketchup pro 2021 , il me met un message d’erreur. Comment ca se fait ??
What version of the IFC?
Do you have the same error message for dwg file?
A common cause is that the IFC version of the IFC model to be imported is not supported by SketchUp.
SketchUp Pro 2021 supports only the version IFC2x3.
Can you view the IFC in a viewer (Solibri, Navisworks,…)?
i used the IFC4 in 2020, 2021, and now 2022. not sure it’s compatible as there are various versions of 4…
No versions of IFC4 are compatible with the SketchUp importer. Use 2x3.
These are classification files and have no influence on the importer, they can be used to classify a model’s objects and when exporting, some attributes are preserved in the ifc output.
Please tell me how you use the IFC, I study the ability, interactions of Tekla and sketchup.
See a post below in which I explain more about how I work with IFC and SketchUp.
Tnx, i will study.
