Is there a conversion process to import an .xlm, xlms … any Excel file into Layout?
You can insert .xlsx files into LayOut. What version are you using? You left that out of your profile.
I am using Sketchup Pro 2018, trying to import Excel 2013. When I insert into Layout the Excel format requires a great deal of clean up. Is there another program that will make Excel files graphic files (.tif. jpeg…?)
Can you share an example XLSX file that shows this?
If you want it as a raster image instead of a table, you can make a screen shot and save it as a PNG or other insertable raster file.
I have tried clipping a screen shot but the resolution is pretty low. I am scaling the image up to a 24 x 36 sheet size for presentation.
I use a program call Screen Captor which will let you save screen shots at 300. Maybe that would help.
I’ll try it . Thanks
Lauot will insert the xlsx file, but the format is not a clean transfer.
Dennis Axberg
AWA Architects
2518 Belmeade Drive
Carrollton, Texas 75006
214-794-5948 dennisaxberg@gmail.com
DaveR - I am using SketchUp/Layout Pro 2018 and trying to import from Excel
2013.
Dennis Axberg
AWA Architects
2518 Belmeade Drive
