Hello, I tried to import a Vectoworks file (dwg) but Sketchup does not recognize it. How can i do?
What version DWG was the file?
The file was not saved as native vectorworks but exported as a .dwg? What does Sketchup say when you try to import? If the .dwg version is too new as suggested above get the sender to resend in an older version or convert it yourself.
It’s from Vectorworkds2019. Actually it opens it but the file is strange, i cannot work on it, like pushing/pulling.
There are most likely no surfaces in the area you are trying to push/pull, just edges. Can you include the Sketchup file here so we can take a look? It the best way to identify what’s happening, it’s the 8th icon across the top.
… and perhaps imports are encapsulated within a component instance ?
You may need to double click it in order to do any edits.
plan situation existante3.dwg (65.2 KB)
Here
test.skp (153.4 KB)
I have tried nearly every option for importing a VW model into SketchUp, and recently found software that does a good job. ‘Transmutr’ is a standalone application (not a plugin for SU.) See below for a comparison of various VW export/SU import approaches. Many of them fail to include the line work, so I’ve shown the results in both SU ‘Default Style’ and ‘Hidden Line’ to illustrate. I feel like Transmutr is the way to go, at least at present.
Thanks for the trial you conducted. Certainly saved me repeating the work.
I hope it’s helpful!
