Hi all,
I import several component into a model. I do it with Sketchup 8 with a script.
Now I use Sketchup 2015 and an updated component library but the time to import component is longer and longer. I mean that the time to import the first component is ok, the second is pretty slow, the third is just a
nightmare ( 60 secondes for a 8 Mo component).
I try to understand why.
Since the last time, I update the component library by adding detail.
I try on Sketchup 8 again, and the time to import is long.
The problem should come from the detail I added.
When I load a component whithout common part with the previous one, time to upload is ok.
I try to group or ungroup, make component or not on the detail that I ad.
I try to change the number of level in the outliner
I import componant manually.
But nothing doesn’t change the time to import for the next componant.
Is there a way to speedup the time to import a component with common part on a previous one?
Sorry for the level of english I try to be clear.
