Im trying to import a revit file with no luck. Also uploaded it to connect but it dont work there either.
Here is the file Transfer - Dropbox , anyone here with revit wich can se what the problem might be?
What version of the importer is being used? apart from the textures, it normally imports:
913-20250313.skp (10,9 MB)
FWIW, for converting in Trimble Connect, the desktop app Trimble Connect for Windows can/could only upload and convert Revit 2022 files and was a beta version. All newer Revit files (this one is 2025) must be uploaded with the Revit addin:
Thanks for your answer.
I just went to “import” an choosed the .rvt-file but that did not work. Do you use a extension for the import?
That explains it when using TC, the Revit user needs to upload it if it should work.
For info, I use sketchup 2026 now.
Thanks for the .skp file!
It imported in less than 30 sec.
You might need to update the extension via ‘hantera’?
