I have a 3D vendor has many formats for import but not .skp nor 3D.dwg is there an extension i need?
The List
Thanks
all of them are 3D CAD formats (besides raster formats as e.g. JPEG and PDF) containing surfaces/volumes based on NURB spline curves, which is not usable in a polygon-based mesh modeler representing everything based on lines and facettes.
You may want use the common, non-proprietary STEP format to convert the NURBS surfaces/solids contained to polygon meshes by importing with the (commercial) SimLab STEP Importer plugin (trial avail.).
I found the files on the 80/20inc web sight under Trimble SketchUp. Needs to be Pro but i am.
Thanks
Your profile says you are using Make.
Your list shows IFC. It is a format supported by SketchUp Pro.
