Convert 3d skp to another format
Hi there,
I drew a 3d skp file, but i would like to convert to one of the following 3d format for my other program to import:
STEP, cadds, catia, iges, imageware, nx, pro/e.
Best if i can export to step file. Is there any extension that i can use?
you can export the SketchUp mesh data to the DWG format (SU Pro only) for opening with every common CAx system.
be aware, that saving in another file format does not change the type and structure of the geometry data, i.e. saving to the STEP/SAT/IGES format etc. does not create NURBS surfaces just by doing that.
Furhter information concerning this data conversion issue can be found here.
Available exporter plugins.
