Hi there, I’m trying to import a dwf file from my laser programme. It imports fine but the scale is out. When I try to re-size, it deletes the model and does not work. Please help!
Can you upload an example or the .dw(…) file itself? Perhaps someone here could take a look at it.
Concept 1_3D.dxf (4.2 KB)
it may be that the model is just very small or very big, after resizing,I have no troubles when resizing it.
For resize of an imported .dwg/.dfx you must enter the component by double-clicking or right-click and choose ‘Edit Component’ then get the tape measurement tool (T) and click two endpoints of a known length. Then just type the length you would want it to be and hit Enter
after a resize, hit Zoom extends (Shift+ Z)
model unit seems to be ‘Meters’ sothat importing in this unit (see “Options… > Scale > Units: Meter”) should lead to the correct size without a scaling afterwards.
