I´m trying to import some images I have downloaded to use on my project, but when I try to import the images using the Default Tray material, they simply do not appear.
The images do appear when I import using File - Import, but it would be easier using the default tray.
Does anyone know what could be happening and how to make the images appear in the Default Tray Materials?
You cannot modify the materials that reside in the default material folders. Only materials in your model can be edited. You must first create a new material and then add the texture to it.
The easiest way to create a new textured material is to import the image into your model, scale it appropriately and then explode it. Or import the image directly as a texture.
