K so needing some guidance re resolution. I only today realized that the send to layout feature, even set to High, send an image that looks fine until you zoom in or print and then it’s a bunch of bitmaps with serious jaggies issues. I got around this to some extent, after much experimenting, by exportin 2D images and sending EPS’s. Nice and crisp assuming they print that way. However I can’t do this for working dwgs because I lose the SCALE feature in Layout and also the ability to annotate/auto extend out dimensions.
Is there a way to jimmy things so that SU will “SEND” crisp EPS files rather than the default, I guess PNG or JPG . . .?
I was wondering what was taking you so long to ask your question.
Look in the SketchUp Model panel found in the tray or under the Window menu.
It looks a bit different in LO2019 than in LO2020 and slightly different on the Mac than PC but it’s there. Of course you must have a viewport or viewports selected to make changes.
