Attatched is my model file. I am trying to make a parametric waffle type roof which I have sucessfully done in box 3. The slightly more complex roof shape in 1 is the one i am trying to make a solid. 2 is not a closed solid and i can identify why hence i have started again with 1. I have copied the shape down on the blue axis and i should be able to connect the corners to form planes between the two, which i did fine using the same process with 2 however I cannot make the same planes in 1.
Alternatively can anyone recommend a free plugin or way that i could extrude the soap bubble shape?
Can anyone help? I’m quite new to this and I’m pretty sure there will be a simple sollution or something I’ve done wrong but i am stumped!
Thanks in advance ![]()
