This is my first time asking for help on this platform, and I hope the community can assist me. I have been using SketchUp for 5 years as part of my work in an engineering office. I am using the Studio version of SketchUp, and in particular, I use the Scan Essentials extension for modeling existing buildings.
As part of my work, I regularly import IFC files. However, for the past 3-4 weeks, I have been unable to import these files. I immediately receive an “Import Failed” error message without the import even starting.
Here is what I have already tried:
I checked the IFC version, which is 2x3.
I tried using other extensions, such as SIMLAB, which managed to import a model but it was completely corrupted (e.g., black faces, multiple groups, and sub-groups).
I reinstalled SketchUp.
I attempted to import the files without any extensions enabled.
Other users have been able to import the models, and I have also tried with files that I have previously been able to open successfully. Nothing has worked…
Has anyone experienced this issue before? Do you know of any solution or an extension that could help?
A quick way of testing if the issue is with (conflicting) extensions is to rename the Plugin folder that resides in this path:
%AppData%/SketchUp/SketchUp 2023
I have the same problem since updated to 2023 version. I use the 2022 version for import and then save it to a skp file.
Really frustrating.
Maybe it’s time too contact the support: prosupport@sketchup.com
Hi Anssi!
Yes have the latest version.
3 months ago I cleaned up my computer and reinstalled everything. Didn’t help. I have contacted the pro support. Letting you know when they answer.
Here’s what worked out for me:
Go to convert3d.org (free and fast web based file converter) and convert IFC file to your desired 3D format. If you convert to 3DS or DAE textures and group hierarchy will be lost. If you need to keep textures and hierarchy, convert to OBJ-format.
To import OBJs to SketchUp I would recommend using Transmutr by lindale.io, which is a fantastic import tool.
Good luck!
/S
if you upload the ifc to Trimble Connect you can convert the ifc to the .trb format, TrimBIM, which is Trimbles BIM format. That format can be imported into sketchup. This gives a light file with the tag/layer structure intact, instead of the native ifc import that somehow for no reason makes big files with no tag structure, the worst of all worlds, so to speak.
This process is of course a lot of moving the files around and clicking the same things over and over again, instead of just having a links palette that does these repetetive operations of updating things automatically, and we will probably get proper collaboration tools in a few years time, if we push hard for it.
Odd_Haakon_Byberg, thanks for your thorough description.
I’ve never really spent time on Timble Connect before. Perhaps I should play around some more with those tools.
So, I managed to upload the IFC file to Trimble Connect (I got a nice 3D preview of the content of the IFC file), convert and save the file again as a TrimBim-file. BUT when importing to SketchUp I get the same “Import Failed” message! Bummer.
Now, it would all be much easier if the IFC import option would just work in SketchUp 2023. My colleague succeeded in importing the exact same IFC file without any problem to SketchUp 2023. I then installed an older version of SkethcUp (2022 Pro) and I was suddenly able to import the IFC file!
I have tried to repair and uninstall SketchUp 2023 but the import error persists.
Sorry, then i dont know what might be causing the ifc to act up like that. If you have access to another resource, you could make a dwg 3D file from it, through Vectorworks for instance. That would also preserve tag/ layer information.
I asked the SketchUp Pro support and got following answer:
I have tried and now it’s working.
“Hello Robin,
Thanks for your reply.
There is a known issue with importing IFC files in 2023 concerning non English characters either in the file name itself or the file pathway folders (this can also include your username directory having special characters). Try moving the file to another location like the desktop as a possible solution.”
