Every time I try and start Layout, it tells me to log out and log back in. I do that and try and restart the program. And the same thing happens every time. And I can’t find any way to contact skechup, just here.
When you installed Sketchup and LayOut did you right click on the downloaded installer and choose Run as administrator? If not, close SketchUp, find the installer, right click on it, choose Run as administrator and then choose Repair when the option is presented. After that do a cold reboot of your computer and see what happens.
Yes I did install it in the proper way.
Try repairing the installation anyway.
What happens if you start SketchUp and sign out there (if logged in)
In Sketchup choose “File/Send to Layout”.
Layout should start linked with the Sketchup File you started it from.
Try fully shutting down your computer and then startup again. Not a restart.
If not follow DaveR’s suggestion to repair installation.
