I have just downloaded Sketchup and can’t get it to launch at all? I can however launch the Layout and Style Builder apps.
I did a search and read that trying to open it in a few different ways may help… like opening a Layout file then clicking on “open with Sketchup” way work. I didn’t.
I have turned of all the parts of the Windows Defender I can find, didn’t help.
Tried the Troubleshooting app in Windows. It didn’t hepl either.
I am running Windows 10 up to date as of today. Its a fresh install as well.
32gigs of ram, and a Nvidia Quadro p5000 gfx card.
I don’t really have any other applications installed that could interfere, as i just installed the OS.
I have tried an SFC and DSIM in powershell… I’m not exactly sure what they do but it was recommended.
I looked at the Event viewer and it says…
Faulting application name: SketchUp.exe, version: 21.1.332.0, time stamp: 0x00000000
Faulting module name: ucrtbase.dll, version: 10.0.19041.789, time stamp: 0x2bd748bf
Exception code: 0xc0000409
Fault offset: 0x0000000000071208
Faulting process id: 0x204c
Faulting application start time: 0x01d7d0cae6467a66
Faulting application path: C:\Program Files\SketchUp\SketchUp 2021\SketchUp.exe
Faulting module path: C:\Windows\System32\ucrtbase.dll
Report Id: 86791585-adba-44a6-b53b-6ee152497ed9
When you installed SketchUp from its exe installer file, did you select its icon and in the right-click context-menu choose “Run as administrator” ?
Do it now and when prompted choose ‘Repair’…
Restart the PC to see what’s what…
It might help …
The file C:\Windows\System32\ucrtbase.dll
Does it exist ?
Try running a powershell [as admin] and type sfc /scannow
That might fix things…
I would strongly suggest another fresh instaalafter creating a new partition on your drive. This will get rid of everything. Also do not use the types of apps that claim to “FIX” things. They are of no value on a properly running system… Also I have found in the distant past, they do more harm than good.
when you get the OS installed, the next items to install are the chipset dtivers from Intel or AMD then the video drivers. Next install SketchUp and it should work.
How about this ?
Uninstall the NET Framework 4.8
Immediately install NET Framework 4.5.2
Restart.
Try SketchUp.
Any improvement ?
Try installing NET Framework 4.8 again.
Restart.
Try SketchUp.
Any improvement ?
Reinstalled Windows 10
Updated Windows 10
Reinstalled my gfx nvidia drivers
Re-downloaded Sketchup
Installed Sketchup
Everything runs great, except Sketchup
Layout works fine.
Style Builder says " You are offline, Check your Internet connection to start using Style Builder"
I’m definitely connected to the internet as I’m typing this… I added an exception allow Sketchup, Style Builder, and Layout through.
