I am trying to use Curic to Level. But when I click on it a dialog box comes up telling me to add a shortcut for Edit Group command and then for Edit Component command. But I do not see an entry in the shortcuts menu for either of these two commands. Even when I select a Group or Component they do not show up in the list
Select a group in the model, open Preferences>Shortcuts and search for ‘group’. You should find the option. Repeat for a component.
Like any other commands that show up in the Context menu, you need something selected in the model space that would make the menu item appear to be able to set a shortcut for it.
Thanks, I was searching under Edit. Searching group found it fine
