I occasionally run into a bug in Sketchup that makes it impossible to create or edit a group or component, by “right-clicking”. I can go to “Edit” in the main menu bar, where I can create either, but cannot edit either. If I shut the program down, and re-open it, everything is normal. Has anyone else run into this problem?
Are you finding that the menu items are grayed out? If so, update SU2021. That problem was fixed in 21.1.332.
FWIW, you can press G to create a component and double click on a component or group with the Select tool to open it for editing, too.
Thanks for the response. I’m on 299, so I’ll upgrade right away.
Or select the object and hit ‘Enter’
