I am looking for an extension that draw two lines from the center point and that two lines are centered automatically as Dibac plugin
I am looking for an extension that draw two lines from the center point and that two lines are centered automatically as dibac plugin.
Dibac plugin can only draw. It cannot apply on wall.
According to picture. I want to draw 4.5 inches exterior wall. Normally, I drawn 2 lines 2.25 inches from the center point. But I want to draw or mark 4.5 inches with one click.
(Sorry for my English)
Profile builder can do that, but there are others
Dibac can do that as well, but you have to adjust the width, and another modifier key to switch from center to outside.
Btw. these tasks might get done faster with just native tools…
It not that complicated.
Let’s try Curic OI with ChalkLine tool on Double line mode
Why stop at just 2? I wish you could divide a line, into X# of portions and simultaneously drag lines from all of the green dots. The process of drawing a line from the green dot (the line division point) to another line or object over and over many times is a waste of time.
G
That’s what Move/Copy-Array is for. No need to divide the line first.
With Curic OI, it’s easy! No redundant edge, no need to delete after copying, object always solid, model always clean, no need to go inside to be able to select/copy.
here is an example for PB3:
  • draw a line (eg.110mm long)
  • click the + sign in the profilebuilder dialog
  • select insertion point, start drawing…
Note: it actually creates a face, which could be colored and is wrapped inside a Group that you can assign a layer automatic, as well…
You can combine multiple walls in an assembly:
assembler
Note how I have asinged varous 3D objects, as well:
PB3-Assembly: 2D standaard met verdiepingsvloer.skp (77.1 KB)
