Natively SketchUp doesn’t have any sounds but s ome extensions add one. The old Housebuilder extension does that, for example. Assuming that it is an extension you installed that does it, you could find it and either disable it or you might be able to edit the code to remove the sound. You would be looking for UI.beep in the script. Change it to #UI.beep and you shouldn’t get the sound anymore. Of course you’ll need to close and reopen SketchUp to get the change to take effect.
My own Mirror tool has always beeped to tell you of any user error, or prompt you with a Yes|No dialog to delete the original selection… both of these messages need a user-action, so a beep draws attention to the situation…
As @DaveR says, you can edit its RB code-file, found inside its Data subfolder, to read #UI.beep [occurs twice]. That disables the beep when SketchUp next opens…
This edit will break its ‘signing’ - but provided you have Extensions Loading Policy set to Unrestricted it’ll be OK…
The old Housebuilder extensions adds the beep which, when loaded, causes a beep on right click even if you aren’t actually using Housebuilder. I have it installed but set not to load normally because of that blasted tone. I only load it when someone asks a question about using it.
Hi TIG
Yes, it is your classic Mirror. It is still work very well. I already set have keyboard shortcut for it
Now I can turn off sound by go to Windows sound setting.
It is great to know @DaveR trick to edit RB code. I might try it later.
Most annoying is “Double Cut” from Mind Sight. If I move component that have Double Cut inside, I always keep hearing warning message, so I end up disable it and just never use it.
After I learn how to remove sound today I may back to try it again.
