yes, joint pushpull by fredo. it’s like a normal pushpull, but on more than one face.
depending on how regular / symetrical the shape is, you could also draw the profile (the thickness) and use a follow me to make it, but that’s only in some cases.
manually, you could also just duplicate your shape, scale it juuuuuuust a little bit down, and then using the line tool stitch both surfaces to make the sides. this one is free and it may look the part, but if you need absolute accuracy (to 3d print maybe) it’s not great.
EDIT : yeah, AnnoNiem has a very good “default tools” solution
Try using the new Follow Me tool under Procedures. If the taper is a consistent angle, draw the end profile as a group (green) and use the base edge as the path. And with Procedures they are easily editable if the profile isn’t quite right.
If the taper angle isn’t consistent then this won’t work e.g. tapered sides and a vertical front.
Wow, thank you all so much! I’m honestly amazed by how helpful everyone has been, taking the time to explain everything in such detail and even fixing the sketchup file!
I’ve spent a long time trying to figure this out without success, so I really appreciate all your help. I’ll give it another go tonight using your suggestions.
What a great introduction to this forum. Thanks again everyone and have a wonderful day!
