How to remove lines between components
Hi, using a plug in to make these cabinets but how do I remove the dark lines between each component? I can’t select individual line…
Assuming you’ve made the cabinets as groups or components, open them for editing and hide the edges you don’t want to see. You can use the Eraser tool with Shift to do that. You may also want to hide the faces between the cases so they don’t show. Another option would be to open the component/group for editing, with Select double click on the face to select the face and it’s bounding edges. Right click on the face and choose Hide. Setting the other components/groups to be hidden when editing a component or group makes this much easier.
There is a paying extension, Eneroth Visual Merge, from the Extension Warehouse. I haven’t tried it myself but it should do the trick.
