Hi,
Impossible for me to reactivate the “Section Plane dialog box” when I create a new section plane.
Just for my drawings “organisation” and naming, I can change section cut name and symbol on the info box but will be great if I can find a solution to make reappear the automatic section plane dialox box.
thanks for your help
Hello,
Unfortunately you can’t easily.
You can by doing something quite tricky :
go to C:/users/“yourusername”/Appdata/Roaming/sketchup/Sketchup 2018/sketchup (assuming you have 2018 version like your profile says), make a backup copy of sharedpreferences.json (we never know) rename it into sharedpreferences.txt, edit it with notepad and change
“ShowSectionToolDlg”: false
into
“ShowSectionToolDlg”: true
save and rename back to sharedpreferences.json
It’ll be back once you open sketchup again.
I found out it also works changing “first_run”: false into “first_run”: true
If you don’t want to launch yourself into this, you could also uninstall & reinstall sketchup…
Hi Paul,
thank you for your quick answer I test and it works great
thanks
Julien
