First time posting here. I couldn’t find my answer looking in other hole questions.
I am trying to move peg holes inside a cabinet, but every way I’ve tried to move them and replicate, the plane of the side of the cabinet remains, covering the hole I’m trying to duplicate. Is there a way to move a hole, then use the #x feature where the surface plane stays gone over the hole?
Unfortunately sketchup has never been good at moving 3d holes like you want, you always need to remove the faces.
But it does move holes on single faces well, so pushpull after.
I believe there are extensions that will do this. Profile Builder or the Flex Tools Wall Cutter could be used. They will even put a hole through multiple groups or components making alignment of things like dowel pins easy in an assembly.
