Hi all, I am currently trying to model the Wembley stadium Arch truss structure. I have played around for a couple of hours but I can’t seem to get the structure I want.
I’ve tried using Curviloft and follow line function to design the circular profile however I am having no luck.
Please find my progress and the model that I hope to produce.
First thought but haven’t tested it yet: I might try Helix along curve to draw bulk of it. Then maybe Path Copy to place the rings joining the helical bits.
Or maybe draw it straight and use Shape Bender or True Bend to bend it.
how would you incline this to say 68’ and can you use the same process to make more of an arc than a semi circle? so say more like 140m (straight line distance from end to end) and 50m high.
To make it the right dimensions, you’ll probably have to draw it from scratch. And if you want it to be an accurate elliptical truss, then you’ll need a better method. Notice how the ends are a bit stretched.
If all else fails, you could buy a model off of Turbosquid…
