How to make PNG instead of JPG with "make unique texture " function?
Change the export type when you export it.
No option for that; I exported by photoshop bridge āedit texture image in external editorā [and this is pure gold option] but I canāt change, file extend :[ , itās always JPG
You can export the texture as a png. Save it locally and then edit it.
long process
Alright. Then the answer is no.
no hacks? this is hard-coded .jpg extension ? Thanks anyway; I need to look on my own then;
If there was an option to change it, youād see an Options button or be prompted to choose a file type as you are when you export a texture image.
NO, but SU doesnāt convert imagesā¦
if you start with a png, SU uses a pngā¦
you can test this by importing a new texture png, apply it, make_unique and then edit itā¦
it remains a png throughoutā¦
john
Once you have a set of textured materials you can use a simple script to export texture files for all of them in one go,
The files can all be made as PNGs if so desired - even it they are currently JPGs.
A āfast-texture-writerā is needed - e.g.
Hereās another version [RB attached]ā¦
http://sketchucation.com/forums/viewtopic.php?p=5357#p5357
Hereās some code to change a texture name/type in situā¦
The first example renames each texture and also PNGs itā¦
https://sketchucation.com/forums/viewtopic.php?p=524826#p524826
https://sketchucation.com/forums/viewtopic.php?p=525945#p525945
Thanks! the last one looks very interesting;
edit:
WOW RenameTextures.rb !! this is it !! love it THX;
