I am currently in a bit of a trouble here.
I have a model with .PNG format textures, but the exporter plugin i’m using (RubyTMIX) does work well only with .JPEG format textures.
I was initially going to download, convert via photo-editing program, re-import into sketchup and re-apply all the texture files, but i quickly realized that it would be an extremely painful and time-consuming operation as the model is quite complex.
So my question is: is there a way or a plugin to convert all the model textures from .PNG to .JPEG format without having to tinker with the model itself?
I often take screen shots for use in communications with others and that produces a PNG file. If I want to use it in Whatsapp, which won’t accept PNG image files, I have to convert it to JPEG. If I click to open the PNG file it opens in Preview and I have an option to export in JPEG format. It’s quick and easy for a single file but I am not sure how you would go about it if you had a batch of files to deal with. I guess there must be a Preview equivalent for Windows.
You get a .DAE file and a folder of textures. Open the .DAE in a text editor, and find everywhere that .png is. Edit the text to make those be .jpg. Save the file.
In the folder of textures will be some number of files. Open any that are PNG in an image editor. On Windows, the Paint program does nicely. Use the File, Save As option, to save a JPG with the same name, into the textures folder (next to where the PNG is).
In a new SketchUp file, use the File/Import option, and either set it to All Supported Types, or specifically Collada.
For the Collada options, make sure both boxes are checked:
As you do the import, click at the Origin to place the imported geometry, so that it ends up in the same place it was before.
You should now have a model that looks the same as before, but will be a lot smaller file.
If in your original model you had a lot of scenes, you could save a copy of that file, delete all of the objects, and purge unused, so that you are only left with the scenes and the styles. Now copy everything in the imported Collada document, and do an Edit/Paste in Place, in the empty copy that you made.
One difficulty you will hit on Windows is that when you make a new document it will expect you to close the existing one, and if you are jumping between files to copy and paste things, that can be inconvenient. You can get around that by shift-clicking on the SketchUp icon in the Taskbar. That will give you a second or third copy of SketchUp running, and then you can keep two or three documents open at the same time.
