Is there a way to get the zero to show up in dimensions that are feet and 0 inches? For example, 12’-0 3/16" instead of 12’-3/16"
There is a feature request for this and hopefully we’ll see it sooner rather than later. Currently, though, you would have to manually edit the dimension to add the 0. It may be important to know that editing the dimension text that way will result in a fixed dimension meaning that a change of length in the SketchUp model won’t be reflected in the dimension so you would need to either edit or replace the dimension.
Right. I’ve seen this feature request out there since at least 2017. Let’s hope we see it sooner rather than never… Thanks for your help.
I feel lucky for being born in a country with a standard dimensioning system.
Why is there a minus sign in the format? Is 12’-03/16" more or less than 12’ ?
The hyphen is a separator. In Fractional units it makes it clear that one and three sixteenths inch is not thirteen sixteenths. 1-3/16" or 13/16". It’s a hold over from the days of hand lettering drawings
The hyphen in Architectural units is a separator between feet and inches normally used when the single and double quotes aren’t. It would be written as 12-8 although it’s seen with the units markings, too, as in 12’-6". Of course dimensions that are short of an inch would benefit from the 0 as in 12’-0 3/16". Things can get a little weird. 12’-1 3/16 might get confused with 12’-13/16" and to prevent that, adding the 0 would help because it would read as 12’-0 13/16" Personally I think the hyphen would still be more useful between the whole inch and fraction than between the feet and whole inches especially if the single and double quotes are being used. But no one asked me when they were setting up the standard.
I thought it was a standard format in LO to have dimensions less than an inch show up with a zero and then the fraction - 3’-0 1/4" .
However, I haven’t been able to do that - today - which is why I am on the Forum looking for the answer. Here’s what I got in my setup:
I don’t believe that is an option although I know the feature has been requested.
Then … at least in this case … I’m not crazy.
Yeah. At least in this case. ![]()
Dave,
Still crazy after all these years …
It’s been 5 years since we had this discussion, and I was searching this morning for a way, in LayOut, to force showing the o in fractional inches. I know that in SU, there is the option to force the 0 in the Units section of Model Info, but I still find no such option in LO.
Do you know of any change in this in the last 5 years?
Kent
PS: BTW, when I tried to do some dimensioning in SU itself after I selected the Force 0 option, it still showed 1’-1/2" for example. I always dimension in LO, but I thought I would try this in SU since the Force 0 option was there.
I do not know. Honestly, I’ve moved on from SU and (thankfully) LO. I’m using Revit full-time now. There are aspects of SU I miss, but not these dead-end feature requests. Good luck!
