How to get measurements in mm layout
Hiya everyone
I have my measurement units set to millimeters but when I measure my house floor it comes up in meters is there a way to change this?
Shane
When you set units here:
File Menu → Document Setup → Units
You’re setting the unit Layout uses in the Value Control Box at the bottom right of the window. If you draw a line and type a length, that’s the unit it will use.
For dimensions, you need to have the dimension tool active then set it in the Dimension Styles Window:
Dimension Style
If mm is your most used unit, set the style in an empty window and save it as your template and you won’t have to do it again.
Thanks so much all fixed sorry it took so long to get back to you
