My 3D printing provider asks for solid drawing, in stl, not only surfaces.
No poblem with the drawing. Only, the (metal) printer notices only the surfaces.
Share an example SketchUp file that has this issue.
SketchUp is a face modeler. Thereâll never be anything inside the faces but if you are creating your models correctly it wonât matter.
Thanks Dave. I did ask my 3D-printer what 3D-system he employsâŚ
Weâll see - Eric
The solution might be at its endâŚ
He employs something like âstudio 2â.
Asking me now if I can thicken the surfaces. I guess not?!
Maybe you can. Again, share the .skp file so we can see what youâve got. Otherwise all we can do is guess and thatâs a waste of your time and ours.
First time, I hope this works.
CANAC BIG - solid.skp (989.0 KB)
Better now?
CANAC BIG - solid.skp (974.5 KB)
Thanks to Wataru too!
Indeed! the build was not entirely closed. Internal faces didnât fully join.
Could I now get it solid?
CANAC BIG - solid.skp (973.8 KB)
What information do you have about this thing that youâre modeling from? As it is your model is really quite messy. I started to try to fix it up but I suspect some of your dimensions arenât accurate as well. I think it would be easier to start over with a clean and correct workflow than it would be to fix what youâve got.
Say as it is, Dave! Anyway, i went to simplify for a start. I thought, if it looks OK from the outside, it is AOK. It is not! Thanks. The simplified:
CANAC BIG - solid.skp (937.6 KB)
How do I go to monochrome?!
The âjunkâ you mention; do you mean deleting the black lines?
View>Face Style>Monochrome.
The junk is the stray edges, surface borders and internal face edges.
As I wrote, I think it would be easier to start fresh rather than trying to beat this work-hardened thing into shape.
