I imported a dwg file. I want to delete multiple tags.Is there a way?
I used to press shift in 2017, but now it doesn’t work.
Please help Thank you!
You can select all imported edges and assign them Untagged, then use the Purge command (in Tags) and it will delete all your unused Tags
Thanks for your reply!
I have tried it, but some of the imported dwg has been grouped, and there are many groups.
I tried to unblock the group, of course, the web page crashed in the end.
Is there any other way?If not, I will repeat it by myself nearly 100 times just to delete the tags…
Edit the dwg file and keep only layer 0.
Use a desktop version of SketchUp.
By ‘unblock’, do you mean Explode groups? Do not select all groups at once, select a few at a time.
Edit the dwg file is the way too,I just used to delete layers in Sketchup
And select a few group to explode at a time is work,Although not as good as before, it is also fast,thank you!
Wait! You mentioned using the desktop version of SketchUp,the desktop version of the $299 plan can select multiple tags to delete?
Thank you!This made me consider whether to buy a desktop version.
Really, the delay in the web version is a bit annoying.
