Hi,
So I am currently doing a multimedia project (year 11) which involves me creating and designing a house, where the viewer is able to walk through the house virtually (but not in editing mood, in a mood where they can only view). I was wondering if this is possible to do it on google sketch up, and if it is how can I?
You can draw a house and set up a walk through (using scenes) in SketchUp and then, if you donât want the viewer to be able to edit the model, either have them use the SketchUp Viewer or export an animation of your walk through.
By the way, it hasnât been âGoogle SketchUpâ for 5 years.
You can however reduce the user interface by hiding all toolbars and trays. You could also set groups/components to be âlockedâ to avoid accidential changes (but right-click unlock makes them editable again). Then you can use the lookaround/walk tool like in a game.
An alternative is to export the model to an external view-only application with first-person camera mode (e.g. web viewers like SketchFab).
So you can use the SketchUp Viewer as I wrote. Or as @Aerilius wrote, you could limit the number of toolbars displayed (if you have the opportunity to set up and control the SketchUp interface) and you could lock groups and components to make them less likely to get edited. If you are sending the SketchUp file to the whomever would be viewing it, if they have SketchUp, thereâs nothing to stop them editing it, though.
Is there a possibility where I can export and allow the viewer to still walk around. I want it to look professional due to part of my assignment is that Iâm replicating an architecture company.
Thatâs what I wrote, an example for a web viewer with such capability is SketchFab. See this example:
(Click the gear button â Navigation â First Person, and then go fullscreen)
You can directly upload from SketchUp to SketchFab with Alex Schreyerâs SketchFab Uploader extension. That requires however that you are allowed to install extensions on the computer that you use (e.g. your own).
I recommend using Unity or Unreal Engine. Those are game engines and basically you can create âyour 3D gameâ that people can walk around -and shoot stuff if you want-. You can send them the âexe fileâ which they open as a game.
But this wonât be an âasapâ solution, youâll need to learn couple of things about those softwares.
Note that Unity supports native .skp files, so you can directly import your model.
