There are many ways, some better than others for specific shapes.
The most basic is to simply use the move tool.
Here I have moved down on the blue axis, then up on the blue axis. I used the up arrow to make it move on the blue axis.
Thanks! This is a cool trick. How about making fillets instead of chamfers?
@DaveR gave you a link to some of the basic video tutorials, did you look at them yet? One of them discusses the Follow Me tool.
Here it is in action.
Hi @Box , why are the edges are smoothed automatically when you moved faces/edges up&down to create the chamfer?
A quirk of fate, perhaps. Maybe because it’s part of a circle in this case. Can’t say I have spent much time contemplating why to be honest.
Who knows what the gods of su plan at any given time.
You’re right, after some testing I just came to a conclusion that if you draw a circle, extrude it, then create those chamfers and that automatic soft&smooth effect happens. (It doesn’t matter if you break the circle with lines afterwards, same thing happens! -partially- However this doesn’t happen with arcs.)
It’s still weird though.
Thanks!
How should I specify the radius of the fillet to a specific value?
How can I change the radius of the fillet to a different specific value in the future?
How can I make the chamfer only on the cylinder edge, but not on the straight edge?
