How to combine several layers into 1
After importing a model, layers on which different parts of this model were modeled were copied into the scene. It is hard to work with a large number of layers
слои
If you delete a tag/layer that is in use, SketchUp will ask what you want to do with the things that used it. Choose a tag you want to keep. Repeat for each extra layer.
It worked. Thanks
How do I know which texture belongs to which object?
Click on a component and then look in entity info.
In current editing context if you right click on the material in a question, in Material tray, the painted object can be selected. However if the material is nested in more deep - e.g. the material applied to face inside group/ component - you have to go to that object editing context, to be able to select.
You can also use the Entity info tray to check the material of selected object.
or use the eyedrop tool in the material panel.
use it on the object and it’ll select the material in question in the panel.
Thanks to
Thank you. Is it possible to group materials?
