Hi, I want to put a small radius or chamber an all edges of my piece, except the 2 wholes.
What would be the easiest/fastest way to do it?
The fastest way would probably be to use FredoCorner of his RoundCorner from Sketchcation. You could do it natively by selecting the edges that need to be chamfered, using Offset to create offset edges at the width of the chamfer and then Move with Autofold to move the edges downward. In either case it would help if you soften the edges between the curved surfaces and the straight ones and then weld the edges.
FredoCorner:
Offset and Autofold:
