My goal is to use ‘path copy’ properly. The problem I was having is that the arc I was using the tool on had too few segments, therefore not making the array of shapes uniform around the arc but rather in bursts of straight lines. I know how to divide the arc however am not sure how I can select it as a single entity when it comes to use the ‘path copy’ tool. I have tried making it a group but then the ‘path copy’ tool doesn’t work.
Yeah I wasn’t expecting this problem. I just used the divide function and then selected 100. Thanks for the suggestion, I will use that plugin if there isn’t a built in option to sketchup that is more simple.
If you need to increase the number of segments in an arc or circle, change the number of segments in the entity window and it will remain an arc. An arc that is connected to other geometry might not be changeable, but for these purposes you could copy it out. The divide commands breaks it into separate edges.
