How can I specify my http company proxy in sketchup 2017 to access online ressources ?
you can’t.
I do not know if SU uses the WinHTTP or WinINET library for acessing the proxy settings but you might want try the following on the Windows console:
• view current WinHTTP default proxy settings:
netsh.exe winhttp show proxy
• set the default WinHTTP proxy server by excluding local addresses:
netsh.exe winhttp set proxy <proxyserver:port> “”
• import MS IE proxy settings of current user as the default WinHTTP settings:
netsh.exe winhttp import proxy source=ie
For an SU x32 under Win x64 the “netsh.exe” command line tool must be run from directory: "C:\Windows\Syswow64"
as always, use at own risk.
I already tried that but this is not working for http authenticated proxies…
This is such a simple feature for a “professional” software !!!
The only way is to use a traffic re-director like Proxifier which forces the program to go through the proxy.
