I have an flat object which is 3mm thick… I want to make it bigger, but keep it 3mm thick, so use the “scale” tool and click on the middle point in one of the corners and now as I move it around, I can change the shape of the object, but only on the red/green axis (so it doesn’t get any thicker).
But this isn’t proportional… I assumed that by holding SHIFT it would keep the object proportional and it does but on the blue axis too, so it gets thicker.
Is there really no way to ‘lock’ the proportions, only on the axis you need?
There are obviously ways to work around this, but I just assumed that if I was only scaling on the Red/Green axis, and used the shift key, it would only keep the proportions on the red/green axis.
Is there another obvious feature I am overlooking?
Jon
