How do I Print Actual Size
I need to make a small pattern to apply to a board. How do I get it to print to full size?
Which version of SketchUp are you really using? The free web based version or SketchUp 2018 which is the Pro version? The answer is different depending on the version you are using.
2015 free version
So 2015 Make? Please update your profile since it isn’t even close to correct.
As for printing full size in SketchUp Make, see this.
Didn’t even know I had a profile. I’ll look into it.
Well, somebody gave you one. At least they didn’t make your nose really huge. :smiley:
Screenshot%20-%208_13_2019%20%2C%204_47_00%20PM
Click on the J in the upper right corner of the forum page and then the gear icon.
Should be a little better now. Thanks Dave.
OK. I have camera set for parallel projection, in top view mode, un-ticked the boxes for fit to page and use model extants.
Scale is set to 1:1, paper size is legal, set to print landscape. (The dwg is 12-7/8" long by 4" high.)
This should print on one page but it shows it will be 4 pages.
The paper size shows as 18.4 x 10.6
I missed something somewhere.
Did you adjust the size of the model viewport to fit close around the model.
No. How do I do that?
Grab the edges of the main SketchUp window and drag them.
Got it !! Thank you sir !!
